Siebel Energy Guide > Premises in Siebel Energy > Replacing a Meter for Maintenance (End User)A malfunctioning meter can be removed from service and replaced with one that works correctly. The original meter can then be repaired and installed at another location. When a meter is removed or installed, the field service administrator must update Siebel Energy so the locations of meters owned by the company can be tracked. |
Siebel Energy Guide |
