Table 13. Business Services Methods
EventRegistrationService |
EnrollAdmin - Used to register one or more individuals. Input Property set is a nested property set where each row is an input contact or prospect. This method is invoked from RegisterAll button, where all dummy records in the current context are registered. |
EventId* |
Input Property - Row Id of the Event. |
Prospect ID |
Input Property - Row Id of the prospect being registered. This property is used by the Siebel Marketing Server during campaign execution. |
Type ('EVENT') |
Input Property - Always set to "EVENT" |
List Id |
Input Property - List Id that contains the contact, if applicable. |
List Owner Id |
Input Property - The list creator Id that contains the contact, if applicable. |
Dummy Id (Dummy regn Id) |
Input Property - Dummy registration record Id. |
Contact Id |
Input Property - The row Id of the contact being registered. |
User Type* |
Input Property - type of individual being registered. "Contact" or "Prospect." |
Return Val* |
Output Property - "Success" or "Failure." |
Output Type* |
Output Property - Further information on the result. |
Shopping Flag |
Output Property - Determines whether the Shopping Cart process is required. "YES" or Null. |
Error Regn |
Output Property - Cumulative error message with additional information. |
EnrollUser - Used to register a single contact or prospect. |
Event Id* |
Prospect Id |
Type ('EVENT') |
Input Property - Always set to "EVENT." |
List Id |
List Owner Id |
Input Property - List creator Id that contains the contact, if applicable. |
Registration Date |
Input Property - Date of registration. |
Contact Id |
Input Property - Row Id of the contact being registered. |
User Type* (Contact or Prospect) |
Input Property - Type of individual being registered. "Contact" or "Prospect." |
Return Val* (Success or Failure) |
Output Type* (Info on the return value) |
Error String |
Output Property - Event Id. |
Error Message (Error encountered) |
Output Property - Description of any error encountered. |
Error Param (User Id) |
Output Property - Contact or Prospect Id. |
Reg Id (Registration Id) |
Output Property - Attendee Id. |
Error Code (Contains Error Identifier) |
Output Property - Siebel Error Id. |
Shopping Flag (YES or "") |
Output Property - Determines whether the event is fee based and needs to go through the Shopping Cart process. "YES" or Null. |
CheckPreviousRegn - Determines if a previous registration or attendee record exists. |
Event Id* |
Prospect Id |
Contact Id |
Error String (Contains Event Id) |
Reg Id (Old regn if it exists) |
Regn Status (Status of the old regn) |
Output Property - Status of previous attendee record. |
CheckSpace - Checks if there is capacity for registration. |
Event Id* |
Input Property - Row Id of the event. |
Prospect Id |
Contact Id |
CleanSpace - Removes any old pending registration or attendee records that do not belong to the current user, to free up capacity. The Business Component User Property "Reservation Time Out Hour" determines how long these records exist before being deleted. |
Event Id* |
Prospect Id |
Contact Id |
Output Property - "Success" or "Failure" |
CreateRegistration - Calls the UpdateSpace method to create a registration and seat counts. Then calls CheckQuote to determine if a quote needs to be created. |
Event Id* |
Prospect Id |
Contact Id |
List Id |
ListOwnerId |
DummyId |
Quote Item Id |
Output Property - Quote Item Row Id. |
Reg Id |
Shopping Flag ("Y" or "") |
UpdateRegistration - Called when a pending registration or attendee already exists. Completes the registration by calling other methods as necessary. |
Event Id* |
Prospect Id |
List Id |
List Owner Id |
Registration Date |
Contact Id |
Reg Id* |
Status* |
Input Property - Status of the registration. |
Quote Item Id |
Reg Id |
UpdateSpace - Creates or updates a regn and updates event counts within a Lock to ensure transaction integrity. |
Event Id* |
Prospect Id |
Contact Id |
Action* (Mode of Operation to be performed - create regn, update regn) |
Input Property - Operation can be performed. Increase count: Enroll an attendee Drop from enroll: Drop an attendee (no functionality present for this currently) Drop from waiting: Drop an WL attendee (no functionality present for this currently) Drop from invited: Drop an invitee (no functionality present for this currently) Waiting to enroll: Enroll an existing attendee (called from Update Regn) Invitee to enroll: Enroll an invitee (called from Update Regn) |
Reg Id |
CheckQuote - Determines whether the current user needs to be charged. |
Prospect Id |
Contact Id |
Reg Id* |
Input Property - Registration or attendee row Id. |
AddToShoppingCart - Invokes the shopping service to create a quote item. |
Prospect Id |
Contact Id |
Reg Id* |
Event Id* |
Input Property - Event row Id. |
Quote Id |
Output Property - Quote Row Id (Returns a quote id if a new quote is created). |
Quote Item Id |
Output Property - Quote Item Row Id (Returns a quote item Id if the quote item already exists in the same Web session). |
SessionRegistrationService |
EnrollAdmin - Used to register one or more individuals. Input property set is a nested property set where each row is an input contact or prospect. This method is invoked from the RegisterAll button, where all dummy records in the current context are registered. |
Event Id* |
Input Property - Event Row Id. |
Session Id |
Input Property - Session Row Id. |
Prospect Id |
Type('SESSION') |
Input Property - Always set to "SESSION." |
Contact Id |
Error Regn (A grouped error message if applicable) |
EnrollEndUser - Used for multi-session registration for a contact or a prospect. Check for time overlaps between selected sessions and existing session registrations. Uses a nested property set. |
Event Id* |
Session Id |
Prospect Id |
Input Property - Row Id of the prospect being registered. This property is used by Siebel Marketing Server during campaign executions. |
Type ('SESSION') |
Contact Id |
Reg Id (Empty) |
Input Property - Registration or attendee row Id. Not used. |
Status (Empty) |
Input Property - Registration or attendee status. Not used. |
Registration Date (Empty) |
Input Property - Registration date. Not used. |
Parent Registration Id (Empty) |
Input Property - Registration or attendee row Id for the session's parent event. Not used. |
Start Date* |
Input Property - Start Date and Time of the session. |
End Date* |
Input Property - End Date and Time of the session. |
Name* |
Input Property - Name of the session (used for error messaging). |
Shopping Flag ("YES" or "") |
Parent Reg Id |
Output Property - Registration or attendee row Id for the session's parent event. |
CheckOverlaps- Determine if any of the sessions selected for registration within the event have time overlaps or conflict with prior registered sessions for the attendee. Uses a nested property set. |
Event Id* |
Session Id |
Prospect Id |
Type ('SESSION') |
Contact Id |
Reg Id (Empty) |
Status (Empty) |
Input Property - Registration date. Note used. |
Start Date* |
End Date* |
Name* |
Error String (Contains Session Id) |
Output Property - Event Id |
Reg Id |
Event Id* |
Session Id |
Prospect Id |
Type ('SESSION') |
Status |
Reg Id (Empty) |
Parent Registration Id* |
Input Property - Registration or attendee row Id for the sessions' parent event. |
Registration Date |
Input Property - Registration date. (Only required if multiple registration records exist for the same contact.) |
Contact Id |
Reg Id (RegistrationId) |
CheckPreviousRegn - Determine if a previous registration or attendee record exists. |
Session Id* |
Prospect Id |
Input Property - Row Id of the prospect being registered. This property is used by Siebel Marketing Server during campaign execution. |
Contact Id |
Reg Id (Old regn if it it exists) |
Output Property - Status of previous attendees record. |
Parent Reg Id |
CheckParentRegn - Determines if the attendee is registered for the session's parent event. |
Session Id* |
Prospect Id |
Contact Id |
Event Id* |
Parent Reg Id |
Parent Status |
Output Property - Status of the session's parent event. |
Session Id* |
Prospect Id |
Contact Id |
Session Id* |
Prospect Id |
Contact Id |
CreateRegistration - Calls the UpdateSpace method to create a registration and seat count. Then it calls CheckQuote to determine if a quote needs to be created. |
Event Id |
Session Id* |
Prospect Id |
Contact Id |
Parent Registration Id |
Input Property - Registration or attendee Id of the parent event. |
DummyId |
Input Property - Dummy Registration Id. |
Quote Item Id |
Reg Id |
Shopping Flag ('Y" or "") |
Event Id |
Session Id* |
Prospect Id |
Status |
Input Property - Status for the registration. |
Registration Date |
Input Property - Date of the registration. |
Contact Id |
Reg Id* |
Input Property |
Quote Item Id |
Reg Id |
Output Property - Registration or attendee Id. |
Session Id* |
Prospect Id |
Contact Id |
Input Property - Registration/attendee Id of the parent event. |
Action* (Mode of operation to be performed - create regn, update regn) |
Reg Id |
Prospect Id |
Contact Id |
Reg Id* |
AddToShoppingCart - Invokes shopping service to create a quote item. |
Prospect Id |
Contact Id |
Reg Id* |
Input Property - Registration/attendee row Id. |
Session Id* |
Quote Id |
Output Property - Quote Row Id. (Returns a quote Id if a new quote is created) |
Quote Item Id |
Output Property - Quote Item Row Id. (Returns a quote item Id if the quote item already exists in the same Web session.) |
