Siebel Events Management Guide > Registering for an Event >
Registering an Account for Financial-Services Customers
You can control which contacts can register for an event by registering an account and issuing invitations to specific contacts associated with that account. Control of which contacts can register is determined by the registration status value you select for the account.
The status value that affects account contacts' (namely, company employees) ability to register is Invited. If the account is registered for the event with a status of Invited, all contacts associated with the account can view the event listing on the Events Web site home page and register for the event.
After an account is registered, the contacts themselves are not registered until action is taken to register individual attendees or attendee lists. An individual attendee can be registered by yourself, the administrator, as described in Registering an Attendee, or by the contact, as described in End-User Procedures for Self-Registering for an Event. A contact list can only be registered by an administrator, as described in Registering One or More Attendees.
NOTE:  An individual attendee can still be invited directly to an event, whether or not that attendee's account is registered for the event. If an attendee registers for an event prior to the attendee's account being registered for the event, Siebel Events automatically registers the account for the event with a status of Restricted Invite.
Additional considerations for registering accounts are as follows:
  • An account can be registered for an event, which automatically registers the account for the event.
  • An account can be registered directly at the session level.
The following procedure describes how to register an account for an event.
To register an account for an event
  1. Navigate to the Site Map > Events > Event view.
  2. In the Events list, select and drill down on the event.
  3. Click the Participants view tab, and then click Company Registration.
  4. To register an account, click the Add Attendee button in the Account Registration list.
    The button appears as available when you set the event Status to Launched.
  5. Choose a registration status according to the visibility and registration options you want to make available to account contacts.
    If you want contacts associated with the account to be able to view and register for the event, choose Invited in the Registration Status field.
    The following table describes typical Registration Status values.
    Field
    Comments
    Attended
    Indicates the potential attendee actually attended the event plan, event, or session. Enter this value only after attendance has occurred.
    Cancelled
    Indicates the potential attendee reversed their previous acceptance before the cancellation deadline.
    Confirmed
    Indicates the participant completed the registration process.
    Invited
    Causes the event to appear in the invitee's My Invitations list on the Web site.
    No-show
    Indicates the potential attendee was confirmed for the event, but did not attend the event.
    Pending
    Indicates the potential attendee has been invited, but has not responded.
    Walk-In
    Indicates the attendee was not confirmed prior to the event, but did attend the event.
Registration Workflow
Siebel Events Management uses workflow rules to eliminate redundant data entry during the registration process.
  • Registering an attendee for the event will automatically register the account for the event if the attendee is associated to an account.
  • If an account has been manually registered for an event then a new contact registration with the same associated account will not impact the existing account registration.
Figure 4 illustrates the process for attendee event registration.
Figure 4. Attendee Event Registration
NOTE:  The term Pre-Registered in the preceding workflow indicates that the attendee has already been registered.
Attendees cannot register for a session until they have first registered for an event. Attendee records are rolled up to the Event Plan level for reporting purposes only.
Session Registration and Activity Records
As part of session management, the workflow performs the following tasks:
  • When a session is first created, the workflow creates an Activity record to track that session, and sets the Activity Type = Session.
  • When an event manager registers a person for the session, the workflow adds the person's name to the list associated with the Activity record.
These workflow activities are generated so that all internal employees who are registered for a session can see that session displayed on their personal calendar within the Siebel application (shown in the Calendar screen). In addition, for all external contacts who are registered for a session, an Activity of Type = Session shows on the contact-centric calendar, which is found in the Contacts screen, Calendar view.
Figure 5 illustrates the workflow triggered during session registration. First, the Event Manager registers attendee for a session. Second, the workflow adds the person's name to the list associated with the activity record, and then an activity displays on the attendee's personal calendar. In addition, the activity displays on the Contacts > Calendar view.
Figure 5. Session Registration Workflow
Removing a Session Activity
If you register an attendee for a session in error, you need to remove the session activity from the attendee's personal calendar. Removing a session activity requires deleting the individual from the Attendee's list for the session, then removing the attendee's name from the Contacts field in the Activities form.
The following procedure describes how to remove a session activity from an attendee's personal calendar.
To remove a session activity from an attendee's personal calendar
  1. Navigate to the Site Map > Events > Sessions view.
  2. In the Sessions list, and select and drill down on the session.
  3. Click the Participants view tab, and then click Attendees.
  4. In the Attendees list, select and the attendee from the list and click Cancel Registration.
  5. Navigate to the Site Map > Activities > All Activities view.
  6. In the Activities list, select the activity.
  7. In the Activity form, from the Contact's field, click the select button.
  8. In the Contacts dialog box, select the attendee, and click Remove.
Troubleshooting Registration
If you are experiencing difficulty submitting credit card information using the Shopping Cart, make sure that Siebel Events Management is properly configured for the database software in use. For more information, see Installing and Configuring Events Management.
Canceling Registrations and Using the Waiting List
In Siebel Events Management, you can cancel registrations only from administrative screens. End users who want to cancel their event or session registration must contact the organization holding the event and ask that an administrator cancel the registration.
When an event registration is canceled, all registrations for specific events and sessions associated with the event are canceled as well. Likewise, if an event registration is canceled, so are all registrations for specific sessions of the event. However, if a session registration is canceled, the event registrations are not canceled.
When the administrator cancels a registration for an event or session that is full, a seat becomes available. However, in some cases, it may be desirable to prevent a seat from becoming available. To prevent a seat from becoming available, the administrator should reduce the capacity immediately prior to canceling the registration.
If the capacity is not reduced, and a seat becomes available, it is allocated to the next user whose registration is added by the administrator or whose registration status is changed from Waitlisted to Confirmed, whichever comes first. In other words, after a seat becomes available, it is recommended that administrators immediately change the registration status of the next wait listed person to Confirmed. Otherwise, a new registrant may accidentally be given the seat designated for the wait-listed person.
The following procedure describes how to cancel an event registration from an administrative screen.
To cancel a potential attendee's registration for an event
  2. In the Events list, select and drill down on the event name for which you want to cancel a registration.
  3. In the Details form, note whether the potential attendee is due any refund of fees, and, if so, the amount to be refunded.
  4. In the Events form, if you want to prevent a seat from becoming available because of the cancellation, reduce the Event Capacity by one. For example, if the Event Capacity is 100, manually change the field to 99.
  5. Click the Participants view tab, and then click Attendees.
  6. In the Attendees list, select the person to be canceled, and click Cancel Registration.
  7. Use your organization's standard procedure to provide any refund due to the person whose registration was canceled.
    NOTE:  It is possible to delete the registration record, rather than set the registration status to Cancelled, but this is not recommended. Deleting the record completely removes information about the registration that can be used to track the number of cancellations, to perform refunds, and so on.
After canceling a registration, the Event form shows that Openings increased by one and Seats Taken decreased by one.
You can give the new seat to the first person on the waiting list, as described in the following procedure. To do this, you first identify the person on the waiting list who has the oldest claim to an open seat. Next, you confirm their interest and availability for the event, and then, you change that person's registration status from Waitlisted to Confirmed. The following procedure is specific to an event; however, the concept can also be applied to an event or a session registration.
To enable the waitlist for an event or session, make sure that the Allow Waitlist check box is selected. By default, all events and sessions have the waitlist function enabled.
To allocate an open seat to a person on the waiting list
  2. In the Events list, select and drill down on the event for which a seat has become available.
  4. In the Attendees list, click the menu button and choose Columns Displayed.
  5. In the Columns Displayed list, make sure the Registered column is displayed.
  6. In the Attendees list, click Query.
    1. In the Registration Status field, select Waitlisted.
    2. Run the query to display all currently wait-listed attendees.
  7. In the Registered column header, click the up arrow to sort the listings by registration date and time.
    The person with the oldest listing on the waiting list is displayed in the first row of the list.
  8. Confirm the potential attendee's interest and availability for the event.
  9. In that person's record, change the Registration Status from Waitlisted to Confirmed.
In certain cases you might want to disable the waitlist function for an event or session. For example, when the capacity is reached, attendees will no longer be able to register for the event or session. An error message is displayed to users who attempt to register for an event that is full, and whose waitlist function is disabled.
To disable the waitlist
  1. Navigate to the appropriate view:
    • For an event, navigate to the Site Map > Events > Event > Details view.
    • For a session, navigate to the Site Map > Events > Sessions > Details view.
  2. In the Details form, clear the Allow Waitlist check box.
