Siebel Forecasting Guide > Overview of Forecasting >
About Forecasting Terms
Table 2 describes some terms which may be helpful as you learn about and use Siebel Forecasting.
Table 2.  Forecasting Terms
Forecast period
The period of a forecast series from start to end date. For example, quarterly.
Summary period
The summary period defines the periodic buckets for the Summary view in the Forecasts screen. Some integer number of these exists for each forecast period (for example, monthly).
Summary Revenues
Each summary period has one summary revenue amount.
Interval period
Period between creation of new forecasts; their frequency. For example, weekly.
Total Forecast Revenue
Sum of each summary record. Each summary period is a summary record bucket.
Detail Revenues
Can be either of summary type or detail type depending on the type of forecast. For more information about forecast types, see About Types of Forecasts.
Sums details and synchronizes totals with summaries.
