Forecast Details view shows product line items that were deleted before creating the forecast. |
While it is unlikely that any best practice would include the deletion of an opportunity that included revenue estimates, end users do have the ability to delete an opportunity. If an end user deletes an opportunity, but does not delete the associated revenues, then those revenues are maintained, and will be included in the next forecast. |
End users should delete each revenue associated with the opportunity before deleting the opportunity if those revenues are not meant to be forecasted. |
Revenues in the Opportunities screen > Revenues view do not appear in the parent account |
End users may find that if they create an opportunity and assign revenues to it before they define the parent account, then those revenues will not be associated with the parent account. |
If end users set the parent account in the opportunity first and then create the revenues, the revenues will be correctly associated with the parent account. |
Cannot create a forecast. [1] An error occurred while creating your forecast. Forecast may not include all revenues or subordinate details. Please check the log file or contact your system administrator for details.
Check the forecast log file on your server to find the source of this problem. These files are typically located as follows: Siebel Mobile Client (siebel.exe) installation:
- xxx: $install/log directory
- yyy: siebel.log, or siebel_N.log, if the client has been run N times since the crash occurred. (The names of the logfiles are incremented by one each run, for example, siebel.log is renamed siebel_01.log, siebel01.log is renamed siebel02.log.)
Microsoft Windows server:
- xxx:$install/siebsrvr/log
- yyy: SrvrComponent_ProcessId.log, for example, SSEObjMgr_50231.log
UNIX server:
- xxx: $install/siebsrvr/enterprises/$enterprise_name/$srvr_name/log
- yyy: SrvrComponent_TaskId.log, e.g. SSEObjMgr_50231.log
A component can have many tasks running and generating logs. See System Monitoring and Diagnostics Guide for Siebel eBusiness Applications for information about the location of log files. |
In the log file, you will find records like this: FCSTLOG_EVENT Error 1 2004-10-30 16:16:02 <WW Sales, 10/01/2004, Product Line Manager-00004456, BGROVES> Error occurred when setting field 'Revenue Class" to value "Backlog"
The error in the previous example occurred on October 30th, 2004, when running a WW Sales forecast for a regional sales manager with the user ID of MSTERN. The error occurred because a revenue record that was to be included in the forecast included an invalid value for the Revenue Class picklist. In this example, the error can be corrected by adjusting the Revenue Class LOV to include a value called BackLog, or by changing the Revenue Class on the offending record to a choice that is still valid. NOTE: It is most likely in this example that the valid values for the Revenue Class field were changed and the old data was never cleaned up.
After this issue is corrected, the forecast can be deleted and rerun, or the missing revenue record can be added manually. |
