Fundamentals > About Records, Fields, and Field Controls > About Field ControlsYou can enter data into the application by typing directly into fields or by using field controls. A field control can be a check box, a drop-down list, a button, and so on. Field controls allow you to do such things as choose from a list of predefined values, enter values in a multi-value field, specify dates, and calculate values. A field control can appear within a form or as part of a record in a list. To use a field control to edit a record in a list, click the control to activate it. In a form, you can see the field control if one is available. In a list, the field control appears when you click in a field that includes one. Related Topics |
Fundamentals |
