Fundamentals > About Records, Fields, and Field Controls >
About Check Boxes
Click the box next to (or below) an option to select or clear the check box. When you click an empty box, a check mark or an X appears in the box. If you click a box that is selected, the check mark or X disappears. Figure 27 shows an example of check boxes.
Figure 27. Example of Check Boxes
Fundamentals
