Fundamentals > About the User Interface > About Using the Drop-Down Arrow for Screen NavigationIf you have access to more screens than can be displayed on the screen, you will see a drop-down arrow at the right end of the set of screen tabs. This drop-down arrow lets you display and select a screen. When you select a screen to display, the last screen tab is replaced with the selected screen. An example of the drop-down arrow for screen navigation is shown to the right of the Assets screen tab in Figure 11. |
Fundamentals |
