Fundamentals > Common Record Tasks >
Displaying Record Count
You can get an accurate count of the number of records in a list without having to navigate to the last record in that list. If you execute a query, this function will show you the total number of matching records in the query.
To display record count
  1. (Optional) Execute a query.
  2. Click the menu button, and then click Record Count.
    The Record Count dialog box appears.
    • If you did not execute a query, this dialog box shows the total number of records in the active list.
    • If you executed a query, this dialog box shows the total number of records that match your current query criteria.
Fundamentals
