Fundamentals > Common Record Tasks >
Finding Information About Records
Use the About Record feature to access system information about a record, such as when it was last edited. An example of the About Record dialog box is shown in Figure 36. To find information about a record
- Navigate to and select the record.
- Click the menu button, and then click About Record.
The About Record dialog box, shown in Figure 36, appears. Some fields are described in the following table.
Conflict # |
Used by Siebel Remote to prevent duplication of records. For more information see Siebel Remote and Replication Manager Administration Guide. |
Modification # |
This number is incremented every time a record is updated. It is used when two or more users try to update a record at the same time. For example, if user A and user B are both reading record AA with modification number 3, and user A updates the record, the modification number changes to 4. If user B then tries to update the record, the system will notice that the modification number of user B's record (3) is old, and user B's update will be rejected. User B will not be able to update the record until it is refreshed with user A's changes. |
Figure 36. Example of About Record Dialog Box
About Accessing the About Record Dialog Box After a Merge
If you access the About Record dialog box after merging records, it displays the last updated date for the remaining record. It does not show the merge date as the last updated date, nor does it show the last updated date for the record that was merged into the existing record.
