Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Default Alarm Snooze Times
You can set up one snooze time for all your alarms from the Calendar tab in the User Preferences screen. To set up a default snooze time for all alarms
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Calendar.
The Calendar screen appears.
- From the Snooze Period drop-down list, select a time between 15 and 120 minutes.
This is the length of time that alarms will wait before triggering a second time after you snooze them.
