Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Meeting Email Notification Prompts
You may want to be prompted by the application to send email messages to meeting participants when you create a new appointment or modify an existing one.
To set up a participant email prompt
  1. From the application-level menu, choose Tools > User Preferences.
    The User Preferences screen appears.
  2. On the link bar, click Calendar.
    The Calendar form appears.
  3. Select the empty Participant Email Prompt check box.
Fundamentals
