Fundamentals > Synchronizing Data >
Illustration of a Synchronization Process
Figure 47 illustrates the synchronization process.
Figure 47. Simulated Synchronization Process
- You make offline database changes on your laptop.
- You dial in and synchronize.
You initiate the synchronization process by choosing File > Synchronize Database from the application-level menu.
- The server sees all the changes made to the server's database and any new or changed data that came from your laptop.
- You see all the changes you made to your laptop's database and any new or changed data that came from the server.
