Fundamentals > Using the Calendar > About Calendar ViewsAs in every Siebel product, the availability of certain features is determined by the configuration of your Siebel application; therefore, the views you see may differ from those described in this discussion of the calendar. Figure 48 shows an example of the Calendar screen. The Calendar has three views:
The Calendar screen also displays a To Do list. Activities appear in your To Do list if you specify them as To Do activities. You can view your uncompleted To Do's in this list. The To Do list is part of the Calendar views, so if you have access to the Calendar views, you have access to the To Do list. An arrow at the top or bottom of the calendar, highlighted in Figure 48, indicates that an appointment occurs before or after the times shown. Use the scroll bar to see the appointment. |
Fundamentals |
