Fundamentals > Using the Calendar >
About Calendar Activity Defaults
When you create a new calendar activity, a number of fields are filled in with default values. These values are shown in Table 16 as they appear in preconfigured Siebel applications.
Table 16. Calendar Detail Field Default Values
Type |
Appointment |
Start |
Current time rounded up to the next calendar interval. For example, if it is 11:02 A.M. and the daily calendar interval specified in your user preferences is 15 minutes, the start time defaults to 11:15 A.M. (If you created the new calendar activity by drilling into a time value along the left side of the Daily or 5 Day Weekly view, the time will be defaulted based on the value you drilled into, regardless of the current time.) |
Duration |
Default value, in minutes, as specified in your user preferences. |
End |
Start time plus the value found in the Duration field. |
Owner |
Your Siebel applications user name. |
