Fundamentals > Using Query to Locate Information >
Simple Query Operators
You can use several simple query operators to define your query criteria. CAUTION: Query operators are reserved in Siebel query language. If you create a query that has a query operator in it, you must put the query in double quotes. For example, running a query for records containing the text call is closed will fail. The word IS falls into the category of reserved Siebel query language because it is used in the query operators IS NULL, IS NOT NULL, and so on. If you put "call is closed" in double quotes, the system will be able to return all records containing the text call is closed. Other reserved operators include apostrophe ('), comma (,), parentheses (()), double quotes (""), tilde (~), and comparison operators such as =, <, and >.
In Table 11, operators are shown in uppercase; however, query strings are not case-sensitive, and the operators do not have to be in uppercase. Simple query operators can be used on their own.
Table 11. Simple Query Operators
Wildcard operator. Placed anywhere in a string, returns records containing the string or containing the string plus any additional characters at the position at which the asterisk appears, including a space. You cannot use * to find dates. To find words on more than one line in a field, you should use * to separate the words. You cannot query for control characters or nonprintable characters, such as line feeds (LF) or carriage returns (CR). |
*rang* finds arrange, arranged, orange, orangutan, range, ranges, ranging, rang, strange, stranger, strangest, strangle, wrangle, and so on.
NOTE: If performance is poor when you use the asterisk (*), substitute "IS NOT NULL" in your query. This often improves performance, and will return the same sets of records.
Wildcard operator. Placed anywhere in a string, returns records containing the characters specified in the string plus any one additional character that appears at the location of the question mark. |
?rag finds brag, crag, or drag.
t?pe finds type and tape, but not tripe.
Surrounds a string that, unless modified by a wildcard (* or ?), must be matched exactly. Quotes let you query for a group of words in its exact order with exact upper or lower case lettering. |
"Sun Solaris" finds records that contain Sun Solaris in the query field.
Placed before a value, returns records containing a value equal to the query value. |
=Smith finds all records for which the value in the query field is Smith. It also turns off wildcards within the query value.
Placed before a value, returns records containing a value less than the query value. |
<6/20/01 finds all records in which the value of the query field is before 20 June 2001. When entering a date, use the format that is specific to your implementation.
Placed before a value, returns records containing a value greater than the query value. |
>5/31/01 finds all records in which the date in the query field is later than 31 May 2001. When entering a date, use the format that is specific to your implementation.
Placed before the value, returns records containing a value that is not equal to the query value. |
<>6/20/01 finds all records in which the date in the query field is not 20 June 2001. <>Paris finds all the records in which the value in the query field is not Paris.
Placed before a value, returns records containing a value less than or equal to the query value. |
<=500 finds all the records in which the value in the query field is less than or equal to 500.
Placed before a value, returns records containing a value greater than or equal to the query value. |
>=500 finds all records in which the value in the query field is greater than or equal to 500.
NOT LIKE, not like |
Placed before a value, returns records not containing the value. |
NOT LIKE Smi* finds all records in which the value in the query field do not start with Smi.
IS NULL, is null |
Placed in the query field, returns records for which the query field is blank. |
Enter IS NULL in the Due Date query field to find all records for which the Due Date field is blank. |
IS NOT NULL, is not null |
Placed in the query field, returns records for which the query field is not blank. |
Enter IS NOT NULL in the Due Date query field to find all records for which the Due Date field is not blank. |
Placed before LIKE and a value with a wildcard operator, returns all matching records regardless of case. |
~LIKE Smi* finds all records in which the value in the query field starts with Smi, smi, SMI, and so on. Using this operator may affect performance.
