Fundamentals >
Using the Site Map
The screen tabs that appear in the application window are determined by your organization and may be only a subset of the available screen tabs. To see a listing of all the screens available to you, use the Site Map.
To navigate to a screen using the Site Map
  1. Do one of the following:
    • From the application-level menu, choose Navigate > Site Map.
    • Click the Site Map button on the application toolbar.
  2. In the Site Map, click the hyperlink for the screen you want to navigate to.
    The Site Map displays the screen and all the views available in that screen.
    NOTE:  If you select a screen or view from the Site Map that does not appear as a screen tab or a view tab in your application, a screen tab or view tab is created when you jump to that screen or view. It will only be visible for the current session.
  3. Click the hyperlink to jump to the screen or view.
Related Topic
About the Application Toolbar
Fundamentals
