Fundamentals > About the User Interface >
About the Application Toolbar
The Siebel application toolbar appears below the application-level menu. The left part of the toolbar, shown in Figure 4, provides access to frequently used tools such as the Site Map. You use the right part of the toolbar, shown in Figure 5, to find information in your Siebel application. The tools available on the application toolbar are described in Table 2.
Figure 4. Frequently Used Tools in the Application Toolbar
Figure 5. Finding Information with the Application Toolbar
Table 2. Application Toolbar Controls
Control
Name
Description
Related Topic
Site Map button
Displays the Site Map.
Using the Site Map
How Do I button
Lets you access iHelp. iHelp provides guidance with tasks.
Using iHelp
Quick Print button
Lets you print the data you are currently viewing.
(Depending on your user preferences, this button may be grayed-out.)
Printing Records
Setting Quick Print Options
Reports button
Lets you access reports for the screen you are working in.
Running Reports
Queries drop-down list
Provides access to your saved queries and to the predefined queries established by your organization.
Using Query to Locate Information
New query button
Launches a new query.
Execute query button
Executes a query after you have defined query criteria.
Search button
Activates the Search Center, which allows you to search for and find records within the database.
Using Search to Locate Information
Fundamentals
