Siebel Hospitality Guide > Using the Function Space Diary > Function Space Diary Overview > Using the Information Display Controls in the Function Space DiaryUsers can change the way that information appears in the Function Space Diary using various controls. Start DateThe date displayed in the Start Date field is the date to which the information currently displayed in the diary relates. Users can enter new dates in the Start Date field to change the day for which information is displayed in the diary. To change the date displayed in the Function Space Diary
Time ScaleThe Time Scale option allows users to change the time intervals displayed in the diary views. Users can display the selected date in quarter-hour intervals, hour intervals, and so on. To select the Time Scale option in the Function Space Diary
DisplayThis option allows users to change the information included in the function summary ToolTips. For example, an event operations associate might be interested in the setup styles, while a chef might be more interested in the meal periods. A revenue manager might want to view the function types. To change the information displayed in the function summary ToolTips
Turn Times FlagWhen the Turn Times flag is selected, the setup and tear-down times are displayed using the pattern set up by the administrator.
Expand All and Collapse All ButtonsUse the Expand All and Collapse All buttons to show and hide data in the Function Space Diary.
Assign ButtonClick this button to assign category bookings to specific space bookings. See Assigning Category Bookings for more information. Dates/Notes ButtonUsers can view notes for the day to understand availability in the context of any special comments or special dates. Click this button to view all notes for the day. NOTE: The dates/notes that are displayed in the dialog box when a user clicks this button are restricted to only those dates/notes that correspond to days that the user sees in the diary. Paging ButtonsThere are four paging buttons that users can use to navigate within the Function Space Diary views: Previous column set, Previous column, Next column, and Next column set. These buttons are located in the upper-right corner of each diary view. Using the paging buttons, users can navigate through the Function Space Diary to reach any required date and time period, moving one week back or one week forward. The following procedure describes how to navigate within a time range, using the paging buttons. To move forward and backward within the Function Space Diary time range
Navigation for Month/Day-of-Week OptionWhen the Month/Day-of-Week option is selected from the Time Scale drop-down list, the information in the diary view changes to display instances of that particular weekday. This change in the diary view alters slightly alters the behavior of the Paging buttons. For example, if a user selects October 24, 2004, four instances of Sunday are displayed in the diary view, October 24, October 31, November 7, and November 14.
Siebel Hospitality Guide |
