Siebel Hospitality Guide > Setting Up Function Spaces, Sleeping Rooms, and Suites > Process of Setting Up Suites >
Setting Up the Suite Category and Assigning Suite-Specific Spaces
An administrator can set up a category to group indivisible or configured specific space suites. After creating the category, the administrator can assign suite-specific spaces to the category. This task is a step in Process of Setting Up Suites. To set up a category for suites
- Navigate to the Property Administration screen > Properties list view.
- In the Properties list, query for the required property.
- Click the link in the Property Name field, and then click the Category view tab.
- In the Category list, create a new category, and set the value in the Type field to Suite.
- Complete the remaining fields, and save the record.
To associate suites with a category
- Navigate to the Property Administration screen > Properties list.
- In the Properties list, query for the required property record.
- In the Category list, select the suites category, and then scroll down to the Specific Space view tab.
- In the Specific Space list, create a new record, select a suite-specific space, and then save the record.
