Siebel Hospitality Guide > Working with Inventory > Management of Functions at the Quote Stage >
Using Reserve and Next Fit to Hold Function Space
The sales manager can use the Reserve button on the Quote Function view to reserve a specific space or category. The manager uses the Next Fit button to find available function space that meets the event requirements.
Reserve
The Reserve button is typically used under the following conditions:
  • If availability checks for the function were bypassed at the opportunity stage, the user updates the availability information in Quote screen's Functions view. This update includes any changes to information about the function space, setup style, expected number of attendees, date, start time, and duration of the event. The user then clicks Reserve to hold the function space, if available.
  • If the user adds a new function to the quote, selects a function space, and completes the rest of the fields for the function record. The user then clicks Reserve, and the specific space, if available, is reserved.
  • If the user wants to change the function space category or specific space, the user can select a different function space and then click Reserve to launch the availability check for the new function space.
  • If a quote has been generated from a nonparticipating property, this button initially changes the value in the Inventory Status field from a null value to Reserved. The user can then use the button to toggle between Reserved and Unreserved as information is supplied from the NPP.
Next Fit
When the Next Fit button is clicked, the best available function space (based on number of attendees, setup style, any specified features, and physical area specified in the function) is selected, and the inventory status is Reserved.
For example, after an opportunity is created and a quote generated, the user reviews the function space availability in the Quote screen's Function view. At this point, the user clicks Next Fit to launch the process of finding and reserving the best available function space.
NOTE:  Users can only click the Next Fit button if a function space has not already been selected and reserved for the function.
In some circumstances, the Next Fit process may not locate any available spaces. In this case, the system returns the best-fit function space with a status of Unreserved.
NOTE:  The user cannot use the Next Fit option when managing NPPs.
