Siebel Hospitality Guide > Capturing Hospitality Opportunities > Adding Details to the Event Opportunity >
Modifying the Opportunity Arrival Date
If necessary, users can change the arrival and departure date information for an event opportunity, or remove the arrival date information. This task is a step in Adding Details to the Event Opportunity. To modify the arrival date in an opportunity
- Navigate to the Opportunities screen > Opportunity List view.
- In the Opportunities list, query for and select the opportunity.
- In the Opportunity form, click the calendar icon in the Arrival date field.
- In the Enter/Change Arrival Date dialog box, select a new date, and then select a value in the Instructions field.
The Instructions values are:
- Click OK to save changes.
To delete the arrival date in an opportunity
- In the Opportunities list, query for the opportunity.
- In the Opportunity form, click the select button in the Arrival Date field.
- In the Enter/Change Arrival Date dialog box, delete the arrival date in the field, and select a value in the Instructions field.
- Click OK to save the modification.
