Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up a Matrix Series >
Creating a Matrix Series
The following procedure details how to create a matrix series record for which an account or segment matrix discount can be defined. This task is a step in Setting Up a Matrix Series. To set up a matrix series for at a property
- Navigate to the Property Pricing Admin screen > Properties list.
- In the Properties list, select the required property and click the link in the Property Name field.
- Click the Matrix Series view tab.
- In the Matrix Series list, create a new record, complete the fields, and save the record.
The following table describes some of the fields.
Series Name |
Enter a name for the series. |
Start Date |
The date from which the series will become effective. |
Start Day |
This field is automatically populated after the Start Date field is completed. |
End Date |
The date after which the series is no longer effective. |
End Day |
This field is automatically populated after the End Date field is completed. |
Product Line |
Select the product line to which this matrix series applies. |
Description |
Enter a description of the series. |
- You must now create either an account or statement discount for the series. For more information, see Defining an Account Matrix Discount or Defining a Segment Matrix Discount as appropriate.
