Siebel Hospitality Guide > Setting Up Products and Assets > Adding Catalog Visibility to Products >
Creating the Product Catalog
The following procedure details how to create a product catalog. This task is a step in Adding Catalog Visibility to Products. To create a product catalog
- Navigate to the Administration - Catalog screen > Catalog Administration list.
- In the Catalog Administration list, create a new record and complete the fields.
Some of the fields are described in the following table.
Name |
The name of the new catalog. |
Description |
A description of the catalog. |
Effective Start Date, Effective End Date |
The date range between which the catalog is effective. |
Private |
Select this check box if you want the catalog to be visible only to users belonging to the access groups associated with it. If the catalog is private, all of its categories will also be private. |
Active |
Select this check box if the category is active. |
Sequence |
The sequence of this catalog in the list. |
