Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Managing Event Room Block Information in Quotes > Updating Room Block Information for a QuoteThe room block information is copied from the opportunity when the quote is generated, but you can modify this information for the quote if necessary. This task is a step in Managing Event Room Block Information in Quotes. |
Siebel Hospitality Guide |
