Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing for Implementation on the DB2 Host > Additional Postinstallation Steps for DB2 Connect > Defining a Database Alias and Testing a ConnectionThis section describes how to define a database alias and test a connection. When you create a connection to DB2 on z/OS, the connection is defined with a database alias that has the appropriate connection information for your database. This alias is the connect string that you specify when you install the Siebel Server. Record the connect string in the copy you made of Deployment Planning Worksheet. To define your database alias, use the DB2 Configuration Assistant or the DB2 Command Line Processor. NOTE: If you define database aliases, you must add the For information on setting values in the db2cli.ini file and for using the DB2 Configuration Assistant or Command Line Processor, refer to the relevant IBM documentation. To test the database connection on the Windows platform
Alternatively, you can use the DB2 Command Window or the DB2 Command Line Processor to test the database connection by typing the following and then pressing ENTER: DB2 connect to dbalias user database userid using database password where dbalias is the database alias you created using DB2 and If the connection is successful, database connection information appears. To test the database connection on the UNIX platform
Implementing Siebel Business Applications on DB2 UDB for z/OS |
