Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing for Implementation on the DB2 Host > Additional Postinstallation Steps for DB2 Connect > Binding the DB2 Connect PackagesDB2 Connect is installed with .bnd files that bind to the host server. You can bind these packages using the default collection ID, or you can create a new collection ID for these packages. The Bind options are as listed:
Issue the BIND command at the time of installation and when subsequent IBM Fix Packs are applied. You issue the BIND command only once per subsystem. If you do not bind DB2 connect packages, SQL errors or authorization errors occur when a client without BINDADD authority attempts to connect and the DB2 software attempts to perform an autobind. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
