Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing for Implementation on the DB2 Host > Setting Up the DB2 Subsystem > DDSNZPARM Parameter Settings for Siebel ApplicationsTo run your Siebel Business applications, you must set the values of some of the DSNZPARM parameters to required settings; other DSNZPARM parameter values are recommended to improve the performance of your Siebel Business applications. This section describes: NOTE: Use the IBM default values for any DSNZPARMs for which recommended or required values are not listed in this section. You can configure some DSNZPARM parameters online, but to configure other parameters, you must shut down DB2. For information on the parameters that can be updated online, refer to the vendor documentation on the IBM Web site. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
