Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing for Implementation on the DB2 Host > Setting Up the DB2 Subsystem > Required DSNZPARM Parameter SettingsThe DSNZPARM values that are required by Siebel Business Applications varies, depending on the version of DB2 for z/OS that you are using:
NOTE: PARTKEYU is only required if partitioning is used with the Siebel Schema. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
