Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Schema on the DB2 Host > Performing a Standard InstallationThis procedure describes how to perform a standard installation. You can use the standard install option as your sole installation procedure, or you can perform the standard installation as the first step of a custom installation, and then customize your deployment after you have completed the standard installation. To perform a custom installation, see Process of Performing a Custom Installation. The standard installation provides two schema layout options: Siebel Schema without Partitioning and Siebel Schema with Partitioning. As shown in Table 13, the storage control file you use during the standard installation is determined by your preferred Siebel Schema layout and your encoding scheme.
See Siebel Storage Control File Templates for descriptions of the templates. If you choose the Siebel partitioned layout, a selected subset of Siebel tables is defined as partitioned with predefined partitioning indexes. For a discussion of partitioned table spaces and partitioning indexes, see Understanding Siebel Partitioning. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
