Implementing Siebel Business Applications on DB2 UDB for z/OS > Configuring the Database Layout > Siebel Objects > Table Objects in Storage Control FilesThe following example illustrates what the Table object looks like in the storage control file: [Object 7149] The Table object illustrated in this section translates into the following DDL output: CREATE TABLE SIEBTO.S_ORG_EXT ( VAT_REGN_NUM VARCHAR(30), Siebel Business Applications include one template per encoding scheme when partitioning is used and one template per encoding scheme for nonpartitioning. Most tables use page-level locking by default, but a few use row-level locking. Table 10 lists tables that use row-level locking. NOTE: LockSize is not defined on the table level, but in the corresponding table space. Table 11 lists tables that use table-level locking. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
