Implementing Siebel Business Applications on DB2 UDB for z/OS > Understanding Siebel Partitioning >
Prepartitioned Siebel Tables
Since release 7.7, Siebel Business Applications provide the following partitioned tables in storage control file templates. The database tables identified in Table 12 represent partitioned Core product tables; seven exceptions are identified as Siebel Industry Applications (SIA) product tables.
Table 12. Prepartitioned Siebel Tables with Physical Columns
Table
Index
Indexed Columns
Trigger Logic
S_ACT_EMP
S_ACT_EMP_P99
PARTITION_COLUMN, EMP_ID
" WHEN (N.IMP_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.EMP_ID,2);
END ¬"
S_ADDR_ORG
S_ADDR_ORG_P99
PARTITION_COLUMN, OU_ID
" WHEN (N.OU_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.OU_ID,2);
END ¬"
S_ADDR_PER
S_ADDR_PER_P99
PARTITION_COLUMN, PER_ID
" WHEN (N.PER_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.PER_ID,2);
END ¬"
S_APPLD_CVRG
Siebel Industry Applications (SIA) table
S_APPLD_CVRG_P99
PARTITION_COLUMN, ASSET_ID
WHEN (N.ASSET_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.ASSET_ID,2);
END ¬"
S_ASSET
S_ASSET_P99
PARTITION_COLUMN, ROW_ID
"WHEN (N.ROW_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.ROW_ID,2);
END ¬"
S_ASSET
S_ASSET_CON
S_ASSET_CON_P99
PARTITION_COLUMN,ASSET_ID
"WHEN (N.ASSET_ID IS NOT NULL)
BEGIN ATOMIC
END ¬"
S_ASSET_POSTN
S_ASSET_POSTN_P99
BEGIN ATOMIC
END ¬"
S_COMMUNICATION
S_COMUNICATION_P99
PARTITION_COLUMN,ROW_ID
BEGIN ATOMIC
END ¬"
S_CONTACT
S_CONTACT_M12
LAST_NAME, FST_NAME, PRIV_FLG, ALIAS_NAME
N/A
S_EVT_ACT
S_EVT_ACT_P99
PARTITION_COLUMN,OPTY_ID
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.OPTY_ID,2);
END ¬"
S_EXP_ITEM
S_EXP_ITEM_P99
PARTITION_COLUMN, OWNER_EMP_ID
"WHEN (N.OWNER_EMP_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.OWNER_EMP_ID,2);
END ¬"
S_FN_ACCNT_TXN
S_FN_ACCNT_TXN_P99
PARTITION_COLUMN, ACCNT_ID
"WHEN (N.ACCNT_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.ACCNT_ID,2);
END ¬"
S_FNCVRG_ELMNTS
S_FNCVRG_ELMNTSP99
PARTITION_COLUMN,APPLD_CVRG_ID
"WHEN (N.APPLD_CVRG_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.APPLD_CVRG_ID,2);
END ¬"
S_INS_CLAIM
S_INS_CLAIM_P99
PARTITION_COLUMN,INSCLAIM_NUM
"WHEN (N.INSCLAIM_NUM IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.INSCLAIM_NUM,2);
END ¬"
S_INS_ITEM
S_INS_ITEM_P99
PARTITION_COLUM, ASSET_ID
BEGIN ATOMIC
END ¬"
S_INSCLM_ELMNT
S_INSCLM_ELMNT_P99
PARTITION_COLUMN,INSCLM_ID
"WHEN (N.INSCLM_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.INSCLM_ID,2);
END ¬"
S_OPTY
S_OPTY_U1
NAME, PR_DEPT_OU_ID, BU_ID, CONFLICT_ID
N/A
S_OPTY_POSTN
S_OPTY_POSTN_P99
"WHEN (N.OPTY_ID IS NOT NULL)
BEGIN ATOMIC
END ¬"
S_ORG_EXT
S_ORG_EXT_U1
NAME, LOC, BU_ID, CONFLICT_ID
N/A
S_PARTY
S_PARTY_P99
BEGIN ATOMIC
END ¬"
S_PARTY_REL
S_PARTY_REL_P99
PARTITION_COLUMN,PARTY_ID
"WHEN (N.PARTY_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.PARTY_ID,2);
END ¬"
S_POSTN_CON
S_POSTN_CON_P99
PARTITION_COLUMN,POSTN_ID
"WHEN (N.POSTN_ID IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.POSTN_ID,2);
END ¬"
S_REVN
S_REVN_P99
BEGIN ATOMIC
END ¬"
S_SRV_REQ
S_SRV_REQ_P99
PARTITION_COLUMN,SR_NUM
"WHEN (N.SR_NUM IS NOT NULL)
BEGIN ATOMIC
SET N.PARTITION_COLUMN = RIGHT(N.SR_NUM,2);
END ¬"
