Table 49. PCD Viewer Toolbar Icons
You can quickly capture response by selecting the right option. For example, click on the first star to denote Continue Discussion. Click the second star to denote Need Data, the third star might denote Accepted, the fourth star might denote Not Interested and the final star might denote that the customer has Rejected the message. NOTE: The number of stars and the associated values is controlled by a List of Values defined for PCD_RESPONSE_TYPE.
Click to close and sign. Sign can immediately navigate you to Signature Capture for Samples screen. |
CTRL + I |
Click to save the session. PCD automatically tracks and updates all the interactions and responses along with duration and sectional information. It also automatically updates the products detailed. |
Click to switch to markup mode where you may have access to markup capabilities to support the discussion. |
CTRL + M |
Erase all markups. |
CTRL + E |
Click to add a contact to this session. For example, in group practices, you can easily add multiple physicians to a session. |
CTRL + SHIFT +Y |
Click to switch between different products messages. |
CTRL + 3 |
Click to lock the PCD Viewer. |
CRTRL + 8 |
Click to view help associated with the message you are viewing. |
CTRL + 1 |
Click to open questionnaire. You can also capture physician's attitude, beliefs and needs using the questionnaires associated to different messages. |
CTRL + 5 |
Click to show disclosure message. |
Click to show related messages. You have access to related messages such as clinical reprints, case studies and so on. |
CTRL + 7 |
Click to drill down to detailed messages. |
CTRL + 2 |
Move to previous slide. |
Move to next slide. |
