Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Member Classes
The Member Class picklist is used for classifying members. Typical values can be Agency, Customer, Salesperson.
To define Loyalty groups, classes, and phases
  1. Navigate to the Administration - Data > List of Values view.
  2. Query for the Type LOY_MEM_CLASS.
  3. Edit the records of this type so there is one record with each of the display values that you want for member classes.
  4. Click Clear Cache.
    NOTE:  New values do not go into effect unless you click Clear Cache.
