Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Process of Setting Up Loyalty Programs >
Creating Base Loyalty Promotions
When you define a program, you must create base promotions to perform the basic processing for the program, such as:
- Adding points to members' balances when they perform accrual transactions.
- Subtracting points from members' balances when they perform redemption transactions.
- Updating vouchers when members perform transactions that use vouchers.
These base promotions apply to every transaction of every member of the program. You should not make them visible to members as promotions. They perform processing in the background. You must create a transaction attribute, to be used by the base promotion that processes cancellations. Then you must create the following promotions for each program:
- Admin - Accruals
- Admin - Cancellation
- Admin - Gift
- Admin - Loan
- Admin - Point Transfer
- Admin - Redemptions
- Admin - Voucher
This task is a step in Process of Setting Up Loyalty Programs. For more information about promotions, see Setting Up Siebel Loyalty Promotions. To create the Transfer Member Id transaction attribute
- Navigate to Administration - Data > List of Values view.
- Add an LOV value record with field values as shown in the following table.
Type |
LOY_ATTRIB_FIELDS_TXN |
Display Value |
Transfer Member Id |
Parent LIC |
Order |
19 |
Translate |
False |
For information about adding an LOV value, see the chapter on working with lists of values in Applications Administration Guide.
- Navigate to the Loyalty Program Administration screen.
- Select the program for which you want to create the base promotions and clear the program's Active check box.
- Click the hyperlink in the Program Id field.
- Click the Program Level Attributes view tab and click Transaction Attributes on the link bar.
- Create a new transaction attribute record with field values as shown in the table that follows.
Name |
Field |
Active |
Selected |
- In the loyalty program form in the upper part of the screen, select the program's Active check box and click Update Cache.
To create the Admin - Accruals base promotion
- Navigate to the Loyalty Promotions Administration screen.
- Add a new record to the Promotions list, and enter the values that are provided in the following table.
Name |
Admin - Accruals |
Always Apply |
Y |
Apply To |
Accrual-Product |
Program |
<Enter the name of the program.> |
Partner |
<Enter the partners for the program.> |
Product Inclusion |
All Products |
Point Limit Type |
Unlimited |
Promotion Start |
<Enter one day before today's date.> |
Promotion End |
<Leave this field blank, because you do not want the base promotion to expire.> |
- Click the Promotion # field's hyperlink.
- Click the Rules view tab.
- Create the rule for this promotion:
- Add a new record to the Rules list, and enter the values in the following table.
Sequence |
1 |
Name |
Check Points |
Apply To |
Transactions |
- Click the Name field's hyperlink.
- Add a new record to the Criteria list, and enter the values in the following table.
Sequence |
1 |
Name |
Check Points |
Type of Comparison |
Compare to Values |
- In the Compare to Values Detail form, enter the values in the following table.
Object |
Transaction |
Attribute |
Transaction Points |
Condition |
Is Greater Than |
- Add a new record to the Values list and enter 0 in the Value field.
- Click the Actions view tab.
- Add a new record to the Actions list, and enter the values in the following table.
Sequence |
1 |
Name |
Give Points |
Type |
Assign Points |
Use From Transaction |
Y |
Object |
Transaction |
Attribute |
To create the Admin - Cancellation base promotion
Name |
Admin - Cancellation |
Always Apply |
Y |
Apply To |
Cancellation |
Program |
Partner |
Product Inclusion |
All Product |
Point Limit Type |
Unlimited |
Promotion Start |
Promotion End |
- Create a rule for this promotion:
Sequence |
1 |
Name |
Invoke Cancel Action for Child Member |
Apply To |
Transactions |
- Click the Criteria view tab.
Sequence |
1 |
Name |
Check Type |
Type |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Type |
Condition |
Equals |
Value |
Redemption |
- Add another new record to the Criteria list, and enter the values in the following table.
Sequence |
2 |
Name |
Check Transfer |
Type |
Compare to values |
Object |
Transaction |
Attribute |
Condition |
Is Not Empty |
Sequence |
1 |
Name |
Cancel Auto Accrual |
Type |
Invoke Custom Action |
Method |
CancelAutoAccrual |
- Add another new record to the Actions list, and enter the values in the following table.
Sequence |
2 |
Name |
Cancel Transaction Attributes |
Type |
Method |
CancelTxnAttributes |
Sequence |
3 |
Name |
Reset Child Qualify Balance |
Type |
Method |
ResetChildQualBalance |
- Create another rule for this promotion:
Sequence |
2 |
Name |
Invoke Cancel Action |
Apply To |
Transactions |
Sequence |
1 |
Name |
Invoke Cancel |
Type |
Cancel Transaction |
Sequence |
2 |
Name |
Type |
Method |
To create the Admin - Gift base promotion
- Copy the Admin - Accruals promotion created in the earlier procedure.
- In the new Loyalty Promotions record, change the following values from the values in the
Admin - Accruals promotion.
Name |
Admin - Gift |
Apply To |
Accrual-Gift |
Leave all other field values the same as in the Admin - Accruals promotion record.
When you copy the Admin - Accruals promotion, the system also copies its associated Rule. In the Rule copy, leave all values the same.
To create the Admin - Loan base promotion
Name |
Admin - Loan |
Always Apply |
Y |
Apply To |
Loan |
Program |
Partner |
Promotion Start |
Promotion End |
- Create the first rule for this promotion, which assigns points when the loan is made:
Sequence |
1 |
Name |
Loan |
Apply To |
Transactions |
Sequence |
1 |
Name |
Loan |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Sub Type |
Condition |
Equals |
- Add a new record to the Values list and enter Loan in the Value field.
Sequence |
1 |
Name |
Loan |
Type |
Assign Points |
Y |
Object |
Transaction |
Attribute |
- Create the second rule for this promotion, which redeems points when the loan is repaid:
- In the threadbar, click Promotion:Admin - Loan.
Sequence |
2 |
Name |
Loan Repayment |
Rule Applies To |
Transactions |
- Click the new rule's Name hyperlink.
Sequence |
1 |
Name |
Loan Repayment |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
- Add a new record to the Values list and enter Loan Repayment in the Value field.
Sequence |
1 |
Name |
Loan Repayment |
Type |
Redeem Points |
Y |
Object |
Transaction |
Attribute |
Sequence |
2 |
Name |
SetLoanBalance |
Type |
Method |
SetLoanBalance |
To create the Admin - Point Transfer base promotion
Name |
Admin - Point Transfer |
Always Apply |
Y |
Apply To |
Point Transfer |
Program |
Partner |
Product Inclusion |
All Product |
Promotion Start |
Promotion End |
- Create the first rule for this promotion:
Sequence |
1 |
Name |
Point Transfer |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
- Add a new record to the Values list and enter 0 (zero) in the Value field.
Sequence |
2 |
Name |
Check Type |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Type |
Condition |
Equals |
- Add a new record to the Values list and enter Redemption in the Value field.
Sequence |
1 |
Name |
Redeem Points |
Type |
Redeem Points |
Use from Transaction |
Y |
Object |
Attribute |
Sequence |
2 |
Name |
Create an Accrual Txn |
Type |
Method |
Point Transfer |
- Create the second rule for this promotion:
- In the threadbar, click Promotion:Admin - Point Transfer.
Sequence |
2 |
Name |
Assign Points |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
2 |
Name |
Check Type |
Compare to Values |
Object |
Transaction |
Attribute |
Transaction Type |
Condition |
Equals |
- Add a new record to the Values list and enter Accrual in the Value field.
Sequence |
1 |
Name |
Assign Points |
Type |
Assign Points |
Y |
Object |
Transaction |
Attribute |
To create the Admin - Redemptions base promotion
Name |
Admin - Redemption |
Always Apply |
Y |
Apply To |
Redemption-Product |
Program |
Partner |
Product Inclusion |
All Product |
Product Limit Type |
Unlimited |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Check Points |
Apply To |
Transactions |
Sequence |
1 |
Name |
Check Points |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Is Greater Than |
Sequence |
1 |
Name |
Redeem the Points |
Type |
Redeem Points |
Y |
Object |
Transaction |
Attribute |
To create the Admin - Voucher base promotion
Name |
Admin - Voucher |
Always Apply |
Y |
Apply To |
Voucher |
Program |
Partner |
Product Inclusion |
All Product |
Promotion Start |
Promotion End |
Sequence |
1 |
Name |
Debit Voucher |
Apply To |
Transactions |
Sequence |
1 |
Name |
Debit Voucher Transaction |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Does Not Equal |
- Add a new record to the Values list and enter Cancellation in the Value field.
Sequence |
1 |
Name |
Update Voucher Status |
Type |
Invoke Custom Transaction |
Method |
DebitVoucher |
- In the threadbar, click Promotion:Admin - Voucher.
Sequence |
2 |
Name |
Cancel Redeemed Voucher |
Rule Applies To |
Transactions |
Sequence |
1 |
Name |
Cancel Voucher Transaction |
Compare to Values |
Object |
Transaction |
Attribute |
Condition |
Equals |
Sequence |
1 |
Name |
Type |
Method |
CancelRedeemedVoucher |
To activate the base promotions
- Select the promotions with the following names:
- Admin - Accruals
- Admin - Gift
- Admin - Loan
- Admin - Voucher
- Click Activate.
