Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Adding Marketing Information to Loyalty Promotions >
Adding Expenses and Line Items to Loyalty Promotions
You can add expected or incurred expenses to a promotion. For each expense record, you can add one or more line items.
To add expenses to a loyalty promotion
  1. Navigate to the Loyalty Promotions Administration screen.
  2. In the Promotions list, find the promotion to which you want to add expenses and click the hyperlink in its Promotion # field.
  3. If the promotion form's Active check box is selected, click Modify.
  4. Click the Expenses view tab.
  5. Add one or more new records to the Expenses list, and complete the necessary fields in each record. Some fields are described in the following table.
    Field
    Comments
    Expense
    Brief title or description of the expense
    Purpose
    Description or code for the purpose of the expense
    Assigned Budget
    Amount budgeted for the expense
    Variance
    Calculated value representing the difference between Forecast Expense and Actual Expense
    Unit
    Indicates whether the expense is Fixed or Per Unit
To add line items to a loyalty promotion expense
  2. In the Promotions list, find the promotion to which you want to add line items and click the hyperlink in its Promotion # field.
  5. In the Expenses list, select the expense to which you want to add line items.
  6. Add one or more new records to the Invoice Line Items list below the Expenses list, and complete the necessary fields in each record. Some fields are described in the following table.
    Field
    Comments
    Type
    Code or description for the type of expenditure detailed in the line item
    Reference
    Description of the specific expenditure detailed in the line item
    Agreement Line Item
    Agreement or contract line item associated with this expense line item
    Project Role
    Role in the company or team of the person responsible for this expense line item
