Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Approving Loyalty Promotions >
Approving or Rejecting Promotions
After loyalty administrators submit promotions, loyalty managers view the promotions and consider them for approval. This task is a step in Process of Approving Loyalty Promotions. To approve or reject a promotion
- Navigate to the Home Page.
- In My Approval Inbox, identify a promotion that you want to consider for approval, and click the hyperlink in its Name field.
- In the promotion form, click the Show More button to display the Approval Status field.
- In the promotion's Approval Status field, change the selection to Approved or Rejected - Manager, as appropriate.
- In the Pick Employee popup box, do the following:
- Select the employee to whom to send a notice of approval or rejection.
- In the Comments field, enter an explanation of or expansion on your decision.
- Click Send.
