Siebel Marketing Installation and Administration Guide > Designing Marketing Campaign Load Formats > About Marketing Integration Objects >
About the Marketing Prospect Integration Object
The Marketing Prospect integration object provides field mappings to typical prospect information from marketing data source(s). The required fields are fields that cannot be a null value for the new record.
Figure 3 shows the integration components for the Marketing Prospect integration object. Required fields apply when a new prospect is inserted into the Siebel transactional database.
Figure 3. Marketing Prospect Integration Components
For a list of fields for the Marketing Prospect integration object, read Field Names for Marketing Integration Components.
Table 21 describes the Marketing Prospect Integration components.
Table 21. Marketing Prospect Integration Component Description
Component
Comment
Campaign Contact
Maps campaign history-level information.
  • User Key: Campaign Id, Load Number, and Token Number
Prospect
Maps prospect information.
  • User Key: Prospect Contact UId
  • Required fields: First Name, Last Name, and Prospective Contact UId
NOTE:  Required fields apply when a new contact is inserted into the Siebel transactional database.
Mapping Rules for the Marketing Prospect Integration Components
Using prospect information for a campaign load requires the following integration components:
  • Prospect. Includes information such as prospect first name, prospect last name, and so on.
  • Campaign Contact. Fields must be mapped in the campaign load report. Mapping includes the required campaign load columns and the keys that store unique IDs from the data warehouse for the prospects being loaded.
Siebel Marketing Installation and Administration Guide Copyright © 2006, Oracle. All rights reserved.
