Siebel Marketing Installation and Administration Guide > Installing and Administering Siebel Marketing >
Guidelines for Testing the Marketing Module in an Integrated Environment
To deploy the Marketing module for segmentation and list generation, you need to install, configure, and test your integrated environment.
  • Installation. You need to install the following products:
    • Siebel Analytics Web Server and Siebel Analytics Server. For more information, read Siebel Analytics Installation and Configuration Guide.
    • Siebel Enterprise Server. For more information, read Siebel Installation Guide for the operating system you are using.
  • Configuration. After installing, you need to configure segmentation metadata, list export metadata, and create example list formats. For information about configuring segmentation and list export metadata, read the chapter about Marketing metadata in Siebel Analytics Server Administration Guide.
  • Testing:
    • After installing the Marketing application and Marketing module, you need to conduct a system test to verify that all components are correctly activated.
    • After you install and configure Siebel Marketing and create segmentation metadata, you need to test campaign load.
This section contains guidelines that help you test a Marketing integrated environment.
To test the Symbolic URL integration
  1. In Siebel Marketing, click the Segments screen tab.
  2. In the Segments screen, click the Segment Designer link.
    If the Segment Designer page does not appear, perform Step 5.
  3. In the Segments screen, click the Segment Tree Designer link.
    If the Segment Tree Designer page does not appear, perform Step 5.
  4. Navigate to Administration - Marketing screen > List Formats.
    If the List Format Designer page does not appear, perform Step 5.
  5. If any of the previous steps do not obtain the specified results or you receive an error, return to Administration - Integration > WI Symbolic URL List and check the Host Administration settings.
To test the Web Services integration
  3. In the Segment Designer, create a test segment and save the segment in the Web Catalog.
    For more information about creating segments, read Siebel Marketing User Guide.
  4. Navigate to the Campaign screen and perform the following steps:
    1. In the My Campaigns list, click New.
    2. In the record, enter a campaign name, and save the record.
    3. Click the Campaign name and click the Design view tab.
  5. In the Design view, perform the following steps:
    1. Click the Segments/Lists link.
    2. In the Segments/Lists list, click Add Segment.
    3. In the Previously Used Segments dialog box, click Choose a new Segment.
    4. In the next Previously Used Segments dialog box, click the Folder Location select button to display the following folders in the Siebel Analytics Web Catalog:
      • Your user name
      • Shared
  6. If you receive an error, perform the following steps:
    1. Navigate to Administration - Marketing screen > Servers view.
    2. Verify the following values:
      • The Marketing Server definition has the correct Authentication user and password
      • All three Web services have the correct Analytics Web Server name in the address
To test navigation links to the Segment Designer page
  1. Navigate to the Campaigns screen.
  2. In the My Campaigns list, click the name of your test campaign.
  3. In the Campaign Details form, click the Design view tab.
  4. In the Design view, click the Segments/Lists link.
  5. Add a segment to associate it with a campaign.
  6. Click the name of the segment.
    The Segment Designer should appear with your segment open for editing.
  7. If you receive an error, verify the following:
    1. Navigate to Administration - Marketing screen > Servers and verify that the Marketing Server definition has three parameters for the navigation views.
    2. Log in to an Analytics URL directly, and verify that the segment request exists and can be opened successfully.
To test campaign load
  1. In Siebel Marketing, click the Segments screen tab and perform the following steps:
    1. In the Segments screen, click the Segment Designer link.
    2. In the Segment Designer, create a test segment and save the segment in the Web Catalog.
    3. Click the Advanced Options tab and verify that a valid Campaign Load List Format is associated with the segment.
  2. Navigate to the Campaign screen and create a test campaign by performing the following steps:
  3. In the Design view, perform the following steps:
    4. Locate and select your test segment.
  4. Click OK twice to associate the segment with the campaign.
  5. In the Campaign form, click Menu and choose Load Campaign.
  6. In the Load Campaign dialog box, click OK to submit the load request.
  7. Click the Execute view tab and select the System Tasks link.
  8. In the System Tasks list, verify that the campaign loads successfully.
Siebel Marketing Installation and Administration Guide Copyright © 2006, Oracle. All rights reserved.
