Table 21. Application Methods Syntax Summary
Attach Method |
Allows an external application to reconnect to an existing Siebel session. |
Dim application as SiebelDataControl Dim status as Boolean status = application.Attach(sessionID As String)
CurrencyCode Method |
Returns the three-letter operating currency code. |
Dim application as SiebelDataControl Dim sCur as String sCur = Application.CurrencyCode
Detach Method |
Returns a string containing the Siebel session ID. |
Dim application as SiebelDataControl Dim sessionId as String sessionId = application.Detach()
EnableExceptions Method |
Enables/disables native COM error handling. |
Dim application as SiebelDataControl Dim bEnable as Boolean bEnable = application.EnableExceptions(bEnable)
GetBusObject Method |
Instantiates and returns a new instance of the business object specified in the argument. |
Dim application as SiebelDataControl Dim busObject as SiebelBusObject set busObject = application.GetBusObject(busobjName as String)
GetLastErrCode Method |
Returns the last error code. |
Dim application as SiebelDataControl Dim iErr as Integer iErr = application.GetLastErrCode
GetLastErrText Method |
Returns the last error text message. |
Dim application as SiebelDataControl Dim sText as String sText = application.GetLastErrText
GetProfileAttr Method |
Returns the value of an attribute in a user profile. |
Dim application as SiebelDataControl Dim sText as String sText = application.GetProfileAttr(profileAttributeName as string)
GetService Method |
Instantiates and returns a new instance of the argument-specified service. |
Dim application as SiebelDataControl Dim service as SiebelService set service = application.GetService( serviceName as String)
GetSharedGlobal Method |
Returns the shared user-defined global variables. |
Dim application as SiebelDataControl Dim sText as string sText = application.GetSharedGlobal(globalVariableName as string)
InvokeMethod Method |
Calls the named specialized method. |
Dim application as SiebelDataControl Dim sReturn as String sReturn = application.InvokeMethod(methodName as String, methodArgs as String or StringArray)
Login Method |
Allows external applications to log in to the COM Data Server. |
Dim application as SiebelDataControl Dim sErr as String sErr = application.Login(connectString as String, userName as String, password as String)
LoginId Method |
Returns the login ID of the user who started the Siebel application. |
Dim application as SiebelDataControl Dim sID as String sID = application.LoginId
LoginName Method |
Returns the login name of the user who started the Siebel application. |
Dim application as SiebelDataControl Dim sUser as String sUser = application.LoginName
Logoff Method |
Disconnects the client from the server. |
Dim SiebApp as SiebelDataControl boolVal=siebApp.LogOff()
NewPropertySet Method |
Constructs and returns a new property set object. |
Dim application as SiebelDataControl Dim PropSet as ProperySet PropSet = oApplication.NewPropertySet()
PositionId Method |
Returns the position ID that describes the user's current position. |
Dim application as SiebelDataControl Dim sRow as String sRow = application.PositionId
PositionName Method |
Returns the position name of the user's current position. |
Dim application as SiebelDataControl Dim sPosition as String sPosition = application.PositionName
SetPositionId Method |
Sets the active position to the Position ID specified in the argument. |
Dim application as SiebelDataControl Dim status as Boolean status = application.SetPositionId(sPosId)
SetPositionName Method |
Sets the active position to the position name specified in the argument. Returns a Boolean value indicating whether or not method succeeded. |
Dim application as SiebelDataControl Dim status as Boolean status = application.SetPositionName(sPosName)
SetProfileAttr Method |
Used in personalization to assign values to attributes in a user profile. |
Dim application as SiebelDataControl application.SetProfileAttr(name as String, value as String)
SetSharedGlobal Method |
Sets a shared user-defined global variable, which may be accessed using GetSharedGlobal. |
Dim application as SiebelDataControl Dim SiebApp as SiebelDataControl boolVal=SetSharedGlobal(varName As String, value As String)
Trace Method |
Appends a message to the trace file. |
Dim application as SiebelDataControl Dim SiebApp as SiebelDataControl boolVal=siebApp.TraceOn(msg As String) As Boolean
TraceOff Method |
Turns off the tracing started by the TraceOn method. |
Dim application as SiebelDataControl Dim SiebApp as SiebelDataControl boolVal=siebApp.TraceOff as Boolean
TraceOn Method |
Turns on the tracking of allocations and deallocations of Siebel objects, and SQL statements generated by the Siebel application. |
Dim application as SiebelDataControl Dim SiebApp as SiebelDataControl boolVal=siebApp.TraceOn(fileName As String, category As String, src As String) As Boolean
