Siebel Object Interfaces Reference > Accessing Siebel COM Data Server with C++ >
Testing Your Program
To test your program
- Start your Siebel client application using the same CFG file and login arguments you specified in the code.
- Choose Screens > Accounts > All Accounts. Verify that there is at least one account visible in the Account list applet. If there is not, create one. Exit the Siebel client.
- Open the CFG file you specified in the code and make sure that the
DataSource key indicates the database source you specified at logon in Step 2.
- In Microsoft Visual C++, choose Build > Build SiebelCOM.exe, or press F7. If there are any errors or warnings reported in the output window, correct the errors and repeat this step.
- Choose Build > Execute SiebelCOM.exe, or press F5.
A message box displays the message "Siebel Data Server initialized."
- Click OK.
The customized dialog box opens.
- The application displays a series of message boxes, with the following messages:
"CFG file loaded." "Logged into Siebel database." "Account BusObject retrieved." "Account BusComp retrieved."
The application displays the name of the first account in the All Accounts view.
