Siebel Object Interfaces Reference > COM Data Server Quick Reference >
Application Methods for COM Data Server
Table 26 lists a summary of the Applications methods' syntax.
Table 26. Application Methods Syntax Summary
Method
Description
Syntax
CurrencyCode Method
Returns the three-letter operating currency code.
Dim application as SiebelApplication
Dim sCur as String
sCur = Application.CurrencyCode(ErrCode as Integer)
GetBusObject Method
Instantiates and returns a new instance of the business object specified in the argument.
Dim busObject as SiebelBusObject
set busObject = application.GetBusObject(busobjName as String, ErrCode as Integer)
GetLastErrCode Method
Returns the last Siebel error number.
Dim iErrNum as Integer
iErrNum = application.GetLastErrCode(ErrCode as Integer)
GetLastErrText Method
Returns the last error text message.
Dim sText as String
sText = application.GetLastErrText(ErrCode as Integer)
GetProfileAttr Method
Returns the value of an attribute in a user profile.
Dim sText as String
sText = application.GetProfileAttr(Name as String)
GetService Method
Instantiates and returns a new instance of the argument-specified service.
Dim Application as SiebelApplication
Dim Service as SiebelService
set Service = Application.GetService(serviceName as String, ErrCode as Integer)
GetSharedGlobal Method
Gets the shared user-defined global variables.
Dim sName as String
sName = application.GetSharedGlobal(varName as String, ErrCode as Integer)
LoadObjects Method
Starts the COM Data Server object and returns a reference to the Application object.
Dim returned as SiebelApplication
application.LoadObjects(pathName\cfgFileName as String, ErrCode as Integer)
Login Method
Allows external applications to log in to the COM Data Server.
application.Login(userName as String, password as String, ErrCode as Integer)
LoginId Method
Returns the login ID of the user who started the Siebel application.
Dim sID as String
sID = application.LoginId(ErrCode as Integer)
LoginName Method
Returns the login name of the user who started the Siebel application.
Dim sUser as String
sUser = application.LoginName(ErrCode as Integer)
NewPropertySet Method
Constructs and returns a new property set object.
Dim oApplication as SiebelApplication
Dim oPropSet as ProperySet
oPropSet = oApplication.NewPropertySet()
PositionId Method
Returns the position ID that describes the user's current position.
Dim sRow as String
sRow = application.PositionId(ErrCode as Integer)
PositionName Method
Returns the position name of the user's current position.
Dim sPosition as String
sPosition = application.PositionName(ErrCode as Integer)
SetPositionId Method
Sets the active position to the position ID specified in the argument. Returns a Boolean value indicating if the method succeeded.
Dim posId as String
Dim status as Boolean
status = application.SetPositionId(posId as String, ErrCode as Integer)
SetPositionName Method
Sets the active position to the position name specified in the argument. Returns a Boolean value indicating if the method succeeded.
Dim posName as String
status = application.SetPositionName(posName as String, ErrCode as Integer)
SetProfileAttr Method
Used in personalization to assign values to attributes in a user profile.
application.SetProfileAttr(name as String, value as String, ErrCode as Integer)
SetSharedGlobal Method
Sets a shared user-defined global variable.
application.SetSharedGlobal(varName as String, value as String, ErrCode as Integer)
Trace Method
Appends a message to the trace file.
application.Trace(message as String, ErrCode as Integer)
TraceOff Method
Turns off the tracing started by TraceOn.
application.TraceOff(ErrCode as Integer)
TraceOn Method
Turns tracing on
application.TraceOn(filename as String, type as Integer, Selection as String, ErrCode as Integer)
