Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > LastRecord MethodLastRecord moves the record pointer to the last record in the business component. SyntaxReturnsAn integer in Siebel VB; a Boolean in ActiveX, COM, Java Data Bean, Siebel eScript. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is for Mobile Web Client Automation Server. SiebelApplication is an Application instance. Private Sub LastRecord_Click() Dim errCode As Integer If errCode = 0 Then Status.Text = SiebelApplication.GetLastErrText See Also |
Siebel Object Interfaces Reference |
