Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > NextRecord MethodNextRecord moves the record pointer to the next record in the business component, making that the current record and invoking any associated script events. SyntaxReturnsAn integer in Siebel VB; a Boolean in Siebel eScript and COM: 1 if the record pointer was moved to the next record, 0 if the current record was already the last record. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is in Siebel eScript. For the equivalent Siebel VB example, read FirstRecord Method. with (this) See Also |
Siebel Object Interfaces Reference |
