Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > NewRecord MethodNewRecord adds a new record (row) to the business component. SyntaxBusComp.NewRecord(whereIndicator)
ReturnsUsageThis new row becomes the current row, either before or after the previously current record, depending on the value you selected for WhereIndicator. You can use NewRecord to copy a record. To place the copy before the original record use the following command. Object To place the copy after the original record, use the following command. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is in Siebel VB: Dim oBusObj as BusObject Set oBusObj = TheApplication.ActiveBusObject |
Siebel Object Interfaces Reference |
