Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > ParentBusComp MethodParentBusComp returns the parent (master) business component when given the child (detail) business component of a Link. SyntaxReturnsThe parent business component of the Link UsageParentBusComp allows you to write code in the child business component that accesses field values and performs actions on the parent business component using the normal business component mechanisms. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is in Siebel VB. For another example, read ExecuteQuery Method. Dim strParentName as String |
Siebel Object Interfaces Reference |
