Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods >
Pick Method
The Pick method places the currently selected record in a picklist business component into the appropriate fields of the parent business component.
NOTE:  In Siebel Business Applications v.7.5.3 and later releases, Pick cannot be used to change the record in a read-only picklist field.
Not applicable
Not applicable
Pick must be invoked on the picklist's business component. When a record is picked on a constrained picklist using the GetPickListBusComp and Pick methods, the constraint is active. Therefore, only records that fulfill the constraint can be retrieved.
Used With
COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script
This Siebel VB example sorts the values in the Sales Stage field.
Sub BusComp_NewRecord
   Dim oBC as BusComp
   set oBC = me.GetPickListBusComp("Sales Stage")
   With oBC
      .ActivateField "Sales Stage Order"
      .SetSortSpec "Sales Stage Order"
      .ExecuteQuery ForwardOnly
      if .FirstRecord then .Pick
   End With
   set oBC = Nothing
End Sub
The following is the equivalent example in Siebel eScript.
function BusComp_NewRecord ()
   var oBC = this.GetPickListBusComp("Sales Stage");
   with (oBC)
       ActivateField("Sales Stage Order");
      SetSortSpec("Sales Stage Order");
      if (FirstRecord())
   oBC = null;
See Also
GetPicklistBusComp Method
