Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > PreviousRecord MethodPreviousRecord moves to the previous record in the business component, invoking any associated Basic events. SyntaxReturnsAn integer in Siebel VB; a Boolean in Siebel eScript, COM, and ActiveX. UsagePreviousRecord may be used only on a business component that has been queried using the FowardBackward CursorMode. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is for Mobile Web Client Automation Server. SiebelApplication is an Application instance. (general) (declarations) Private Sub PreviousRecord_Click() See Also |
Siebel Object Interfaces Reference |
