Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods >
SetFormattedFieldValue Method
SetFormattedFieldValue assigns the new value to the named field for the current row of the business component. SetFormattedFieldValue accepts the field value in the current local format. Syntax
BusComp.SetFormattedFieldValue FieldName, FieldValue
FieldName |
String containing the name of the field to assign the value to. |
FieldValue |
String containing the value to assign. |
Returns
Not applicable Usage
This method is useful when you write code for a Siebel configuration that is used in multiple countries with different currency, date, and number formats. This method can be used only on fields that have been activated using ActivateField. Used With
Browser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script Example
This Siebel VB example is a fragment from a program designed to track the velocity of an opportunity through its sales stages. (general) (declarations) Option Explicit
Dim OpportunityBO as BusObject, StageBC as BusComp Dim OppStageId as String, SalesRep as String, Stage as String Dim StagePrev As String, StageDate as String, StageDatePrev as String Dim Dx as Double, Dy as Double, Diff as Double, DiffStr as String Dim OppID As String, OppStageId as String, StageID As String Dim SalesStageBO as BusObject, SalesStageBC as BusComp
Set SalesStageBO = TheApplication.GetBusObject ("Sales Cycle Def") Set SalesStageBC = SalesStageBO.GetBusComp("Sales Cycle Def")
With SalesStageBC .SetViewMode AllView .ClearToQuery .SetSearchSpec "Sales Cycle Stage", StagePrev .ExecuteQuery ForwardOnly .FirstRecord StageId = .GetFieldValue("Id") End With
'Instantiate stage BC Set StageBC = OpportunityBO.GetBusComp("Opportunity Stage")
'Check that we do not already have a record for the stage
With StageBC .SetViewMode AllView .ClearToQuery .SetSearchSpec "Sales Stage Id", StageId .ExecuteQuery ForwardOnly
'Proceed further only if we do not already have record 'opportunity sales stage
If (.FirstRecord = 0) Then 'Create a new stage record and write it out .NewRecord 1 'Record Id for future use OppStageId = .GetFieldValue("Id") .SetFieldValue "Opportunity Id", OppId .SetFieldValue "Sales Stage Id", StageId .SetFieldValue "Sales Rep", SalesRep .SetFormattedFieldValue "Entered Date", StageDatePrev .SetFormattedFieldValue "Left Date", StageDate Dx = DateValue (StageDatePrev) Dy = DateValue (StageDate) Diff = Dy - Dx DiffStr = Str(Diff) .SetFieldValue "Days In Stage", DiffStr .WriteRecord End If End With
See Also
ActivateField Method SetFieldValue Method
