Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > SetFieldValue MethodSetFieldValue assigns the new value to the named field for the current row of the business component. SyntaxBusComp.SetFieldValue FieldName, FieldValue ReturnsUsageThis method can be used only on fields that are active. For details, read ActivateField Method. For applications in standard interactivity mode, write the record immediately after using SetFieldValue by calling WriteRecord. FieldName must be enclosed in double quotes, and must be spelled exactly as the field name appears in Siebel Tools (not in the status line of the application or the column head), with the correct case; for example, FieldValue must not have a length that exceeds the defined length of the field. For example, passing a 20 character string into a field that is defined as being 16 characters long results in the runtime error "Value too long for field 'xxxxx' (maximum size nnn)." A good practice is to check the length of the string against the length of the destination field before using SetFieldValue. To set a field to null, follow this example. Do not use the SetFieldValue method on a field that has a pick list. Instead, use the following procedure.
NOTE: SetFieldValue cannot be used with calculated fields and cannot be used recursively. Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExampleThe following example is in Siebel VB: Dim CurrOppty as BusComp The following is the equivalent example in Siebel eScript. var CurrOppty = this; See AlsoActivateField Method |
Siebel Object Interfaces Reference |
